Power went out several days ago. I tried to connect directly to the switch via usb-c and follow the directions but it didn’t work. This happened before and the switch had to be replaced. Switch shows pending on the app.
Hi @trevor
If there was a blackout or power outage and the switch show pending for that, most possible your switch is running the wrong code which we call ‘routing code'
MAC address: Physical address of the device this never changes
The IP address is a logical address assigned by your local router to the device (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the IP address of the switch 'currently'
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not I will leave you a guide how to perform a IP scanner on your local network to identify the switch IP.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router>enable (hit enter to accept the command)ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait : until the flash finished )ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command : the switch will reboot )
How to Fix Routing code issues on Lennar Home users
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
4-If the access via IP address is not possible here is a guide how to access using a console cable (usb to usb type C )
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
Can you verify if my switch is under warranty?
Will you please repair or replace? I tried to get to the dashboard via usb-c and couldn’t connect.
