Hi, I am in a recently bought Lennar home which came with a ICX7150 switch with two access points. I have 1gbps fiber connection and it was all working great till I had a power outage and the switch rebooted. Since then my network is terrible. I searched the forum and similar issues reported and the solution seems to be to get the switch to boot up with switch firmware. I logged into the switch console (it says unleashed) and it is showing internet is connected however switch is in disconnected state.
I connected to the switch to the usbc port and was able to see the boot up sequence. Below are the messages
ICX7150-Boot>boot
device 0 offset 0x0, size 0xc0000
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
5 ecc_errors after reading 1b48000:1b49c00
iproc_nand_read_page returned 2
NAND read from offset 0 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
It is booting from secondary using the image SPR0809d.bin which I think is the router image while I need the switch image to solve the problem. Booting from secondary image it is asking me for login / password which I do not have. I will try the ones provided in the below post -
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
I attempted to tftp the switch image into primary partition, however the switch does not seem to able to ping the tftp server. I am on Windows 10 laptop using Solarwinds tftp server.
Here are my questions.
1. Is there a way to reset the login / password for the secondary partition ? I interrupted the boot sequence by pressing b and that is getting me to a ICX7150-Boot prompt.
2. Though the error is saying "ERROR: can't get kernel image! could not boot from primary, no valid image;" I am assuming the switch firmware needs to be loaded into primary partition. Am I missing anything ?
3. If I cannot get switch to reach my tftp server (running on windows 10) how do I flash the switch firmware to primary partition? Are there any other options I can try ?
I am very much stuck at this point looking for help. This clearly is not for an average home owner and requires specialized skills. I have been trying to resolve this for weeks now and it is very frustrating Lennar or Ruckus does not offer any support besides this forum. I think these type of issues could be resolved quickly if phone support is provided. Thank you!
