Hello, I recently had a power outage and I wanted to ask about some issues I'm having.
Firstly I want to mention some observations. The SSID is still broadcasting/you are still able to connect. Those devices that are plugged in through ethernet are able to connect as well. When looking at the access points with the lights at the bottom there are four lights on, 2 green 1 yellow 1 green
When you first connect to the WiFi you are able to reach all websites (slowly, but not too slow). After about 20-40 seconds you will notice that you are not able to reach those websites; if you refresh you will not be able to connect.
All I have done is switch devices using the ruckus to my modem.
Is there something that can be done about this?
