wnate2448_aol.com_NEW MEMBER18 October 2026, 8:38 AM
I am respectfully requesting a RMA Ruckus switch for my existing Ruckus switch that is malfunctioning. On the forum posts, many individuals are experiencing the same problem with the Ruckus switch. individuals are experiencing the same problem with the Ruckus switch.
For example, my switch does exactly the below::
RUCKUS ICX-7150-C12P - constant power cycling. Serial No. FEK3817Q9CH.
This seems to be a recent common issue as I can see other forum posts are encountering the same issue - Since October 1, 2026, my main Ruckus Switch and (2) ceiling access points keep power recycling. My Ruckus WiFi network will be available for two to 15 minutes before everything shuts off. The access points will turn completely off with no lights, the main Switch will have a solid green, but the syst light will alternate between flashing orange, solid orange, and solid green (for the short time it does remain working). The Ethernet port lights will be off when the access points are shut off as well. Then everything will cycle back on again before it shuts down after just a few minutes. The ruckus WiFi connection just won’t hold longer than 5 min at a time, but the main wifi from the router will, so the ruckus system as a whole is malfunctioning. I have sent you seven photos, including videos of the Ruckus switch malfunctioning the AP port showing dark.
Can you please assist me in getting an RMA started?
This is a Lennar home. I tried unplugging and replugging. And also tried hard resetting the switch.
The power source is working properly.
I have ever done any maintenance on this equipment nor have I tried to upgrade the equipment since the seven years of moving into my Lennar home.
When I do get switch power, the power light on the switch remains solid green. The switch and the APs seem to reboot every 2-15 mins so I will see the AP lights turn off, then red, then orange, then green, before it decides to reboot and repeat that same cycle - while the main Switch poe stays green but syst light alternates between green, flashing/solid orange and Ethernet ports will also alternate between green and no lights.
So basically, it just goes back and forth between working and not working/rebooting. So I just stay on my main wifi connection not through ruckus anymore.
My problem is exactly the same problem as your Forum Poster @Bebeast who received a RMA Ruckus switch replacement from you already for the same malfunctioning problem.
Your company, Ruckus, determined that based on the troubleshooting performed, the ICX-7150-C12P Switch is not responding properly. A hard reset was also attempted; however, the issue still persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
again, I kindly request that you promptly assist me with RMA Ruckus switch to replace my because it has affected all of my smart to not work at all. again, I have already provided you with photos and videos of my system malfunctioning. I kindly very much in advance for your prompt response to my request. Please don’t hesitate to call me at my telephone number.
