Hi, im Alex, IT analyst.
Im having problems with my Ruckus access points. i have 40 APs throughout 4 different plant locations.
Lately ive been getting a lot of reports of WiFi disconnections & slow internet, and ive noticed its mainly caused by clients constantly changing between APs, often end up staying stuck in the one that is far away, causing them to have very low Db, such as -80 and -100. another issue is clients alternating between 2.4g and 5g a lot, which cause disconnections, i think. ive already enabled SmartRoam and set the roam factor to different values across different days to do some testing, didn't notice any benefit.
ive also made some heatmaps of the offices, but coverage doesnt seem to be the issue, since this happens to clients that are close to the AP. ive also adjusted the TX power manually based on AP models and distances between them, hoping to reduce interference, also enabled auto cell sizing in some, but still, no luck. i tried activating chanelization, but im not sure if its for good or bad.
we have 500Mbps symmetrycal internet in the office, and when i run speed tests on my laptop i get speeds of around 380-400, so im not sure if bandwifth is the issue, i think its more caused to bad roaming, sticky clients, and alternating between bands.
Im out of options, i dont have that much experience in IT, much less managing wireless networks, so i was hoping to get some advice from someone who might have more experience than i do.
