Hello Ruckus Support,
I'm reaching out regarding ongoing issues with my Ruckus ICX7150-C12-POE switch and two R510 access points. Despite extensive troubleshooting, firmware updates, and system diagnostics, the network continues to experience repeated outages.
System Information:
- Switch Model: ICX7150-C12-POE
- Serial Number: FEK3803R0VA
- Access Points: Two Ruckus R510s
- Firmware Version Reported in Diagnostic Output: 08.0.80dT211
Description of the Issue:
Both access points intermittently lose power completely, with their indicator lights turning off, before automatically powering back on and reconnecting.
These outages occur without any user intervention and have become a recurring problem.
Initially, I suspected the access points themselves. However, because both devices are experiencing similar power interruptions, I'm increasingly concerned that the underlying issue is with the ICX7150 switch, specifically its PoE subsystem, internal power supply, or the switch itself restarting unexpectedly.
Troubleshooting Already Performed:
We have spent considerable time troubleshooting this system, including:
- Performing a firmware update.
- Conducting a full switch and system health check.
- Reviewing system event logs and PoE diagnostic logs.
- Checking PoE power allocations and actual consumption.
- Verifying PoE detection and power delivery to both access points.
- Reviewing individual switch port status and configurations.
- Investigating potential PoE power budget limitations.
- Monitoring the system for additional failures and unexpected restarts.
- Reviewing access point logs to investigate the recurring outages.
Despite these efforts, the problem has not been resolved.
Findings From the Diagnostic Logs:
The diagnostic output raises several concerns:
1. Possible switch or PoE subsystem restarts: The PoE event logs show power being initialized and allocated across multiple switch ports, followed by powered-device detection and power being enabled. This behavior is consistent with a switch startup or PoE subsystem reinitialization.
2. Both access points are affected: Ports 1/1/2 and 1/1/7 successfully detect powered devices and enable power. However, both connected access points continue experiencing unexplained power interruptions.
3. Unexpected power reporting: The PoE diagnostics report approximately 7 watts of consumption and 30.8 watts of allocated power. I would appreciate confirmation that these readings are normal for two connected R510 access points.
4. Incorrect system timestamps: The switch diagnostic output reports January 1, 2000, suggesting the system clock may not be properly synchronized. I would like to determine whether this is associated with unexpected switch restarts.
5. Management connection interruption: During diagnostic collection, the management session unexpectedly disconnected. While this does not conclusively establish a switch reboot, it raises additional concerns about overall switch stability.
The available logs do not conclusively establish whether the entire switch is restarting or whether the PoE subsystem is independently resetting. However, the recurring simultaneous issues affecting multiple access points suggest a potential problem with the switch rather than two independent access point failures.
Request for Support / Hardware Replacement:
At this point, I would appreciate having this escalated for a hardware evaluation and potential warranty replacement (RMA).
We have already completed extensive troubleshooting, including firmware maintenance, system checks, and log reviews, without resolving the recurring outages.
I would specifically like Ruckus to:
1. Review the diagnostic logs to determine whether the switch itself is rebooting or its PoE subsystem is resetting.
2. Determine whether the symptoms indicate a failing internal power supply, PoE controller, or other hardware component.
3. Confirm whether the switch is eligible for warranty replacement or RMA.
4. Advise whether any additional targeted diagnostics are required before authorizing a replacement.
I would prefer not to repeat the same basic troubleshooting steps that have already been completed unless there is a specific reason to do so.
I can provide the complete switch diagnostic output, system logs, and access point logs for review.
Thank you for your assistance. I look forward to resolving this issue.
