so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
Hello @LD ,
As per the case description, I understand that you are facing slow or intermittent connectivity issues after the power outage and unable to login to the Unleashed app.
To assist you further, I would require few configurations from your Switch.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
/kb/articles/10-how-to-find-the-ip-address-of-the-ruckus-devices-switch-and-aps-using-ip-scanner-free-applications
/kb/articles/8-how-to-access-the-command-line-interface-cli-of-the-ruckus-icx-7150-c12p-switch
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
Hi Pinky, I found ip address for ruckus. But when I go into terminal from my Apple laptop it say no matching host key type found. Pasting the response from command line. IP address striked out.
‘Unable to negotiate with ———— port 22: no matching host key type found. Their offer: ssh-rsa’
From the above response you shared, I understand that you are able to get the IP address of the Ruckus Switch.
Could you please use the same IP address to login to the web browser and confirm if you are able to access the Switch dashboard?
You should observe the Switch Dashboard, which should be visible upon accessing the appropriate IP address, as illustrated in the screenshot below.
Please let us know if you are able to access the dashboard with the obtained IP address.
So, on the Firefox I added the http and ip address. Now I am on ruckus unleased , it’s asking for username and password
