I upgraded my ATT wirless modemat home and after that the access point pwoer is not on and also not showing green light on the ruckus icx7150.
Hello @varunkrissj
We appreciate the information you provided regarding your issue with the RUCKUS ICX-7150-C12P Switch and the Access Points not receiving power.
Based on the details you shared, it appears that the SYST&PWR indicator on the RUCKUS Switch is showing green, suggesting it is in a normal operational state. However, this issue may stem from the PoE ports on the Switch being disabled.
To assist you further, we recommend following the troubleshooting steps outlined in our RUCKUS Lennar Knowledge Base article. This resource provides a detailed guide on resolving issues where there is no power to the Access Points and the ICX-7150-C12P Switch displays a green indicator.
Please refer to the following link for detailed instructions:
/kb/articles/6-no-power-on-access-points-and-icx-7150-c12p-switch-with-green-lights-on-syst-pwr-and-poe-disabled
Kindly follow the steps outlined in the article, and do not hesitate to reach out if you encounter any challenges or require further assistance along the way.
Imran Sanadi RUCKUS Lennar Home Community
While i am following the link, i got stuck at username/password. what are the username/password.
/kb/articles/10-how-to-find-the-ip-address-of-the-ruckus-devices-switch-and-aps-using-ip-scanner-free-applications
Hi @varunkrissj
Please try to log into the Switch CLI using the default credential.
Switch default credentials will be as mentioned below.
Username: super
Password: sp-admin
If the above credentials don’t work, you can try below default credential combinations as well.
I tried with all combinations username/password mentioned but not working,
Could you please attempt to access the CLI using the Telnet option? Telnet does not require a username or password.
For instructions on how to access the Command Line Interface (CLI), please consult the following RUCKUS Lennar Knowledge Base article:
/kb/articles/8-how-to-access-the-command-line-interface-cli-of-the-ruckus-icx-7150-c12p-switch
If you have any questions or concerns regarding this process, please do not hesitate to reach out.
HelloImran,
The CLI helped me to get all access point power on and now can you provide steps for updating firmware or any other things. its been long time i updated.
Please share the below command outputs to check your current Switch version and assist you accordingly.
show version
show flash
Sure, please find below details
telnet@ICX7150-C12 Switch>enableNo password has been assigned yet...telnet@ICX7150-C12 Switch#show version Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserv ed. UNIT 1: compiled on Feb 17 2017 at 16:03:13 labeled as SPS08060 (23946048 bytes) from Primary SW: Version 08.0.60T211 Compressed Boot-Monitor Image size = 786944, Version:10.1.09T225 (mnz10109 ) Compiled on Sat Feb 18 00:15:43 2017 HW: Stackable ICX7150-C12-POE==========================================================================UNIT 1: SL 1: ICX7150-C12-2X1G POE 12-port Management Module Serial #:FEK3229N086 Current License: P-ASIC 0: type B160, rev 11 Chip BCM56160_B0==========================================================================UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module==========================================================================UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module========================================================================== 1000 MHz ARM processor ARMv7 88 MHz bus 8192 KB boot flash memory 2048 MB code flash memory 1024 MB DRAMSTACKID 1 system uptime is 3 hour(s) 32 minute(s) 29 second(s)The system started at 00:02:27 GMT+00 Sat Jan 01 2000The system : started=cold start--More--, next page: Space, next line: Return key, quit: Control-c^Ctelnet@ICX7150-C12 Switch#show flashStack unit 1: Compressed Pri Code size = 23946048, Version:08.0.60T211 Compressed Sec Code size = 23946048, Version:08.0.60T211 Compressed Boot-Monitor Image size = 786944, Version:10.1.09T225 Code Flash Free Space = 1307496448
Thank you for your response and the information provided.
Based on the screenshot you shared, it appears that your current Switch is running on an older non-UFI 08060 version resulting in such issues. To ensure optimal performance for Lennar Homes users, I recommend upgrading the Switch to a recommended version.
For detailed instructions on how to upgrade the RUCKUS ICX-7150-C12P Switch from a Non-Unified Forwarding (Non-UFI) version, please refer to the RUCKUS Lennar Knowledge Base self-help article available here:/kb/articles/1-how-to-upgrade-ruckus-icx-7150-c12p-from-non-unified-forwarding-image-ufi-to-a-stable-ufi-version
Since you have access to the CLI, I recommend following the 2nd option outlined in the article.
Please proceed with the upgrade process and feel free to reach out if you encounter any challenges or require assistance during any step of the process.
Hello Imran, While upgrading it is failing at "copy tftp flash 10.176.220.51 SPS08095hufi.bin primary" . i downloaded from the https://support.ruckuswireless.com/software?filter=108#sort=relevancy&f:@source=[Software%20Downloads]&f:@commonproducts=[ICX%207150] and placed under the Upgrade folder.
telnet@ICX7150-C12 Switch>enableNo password has been assigned yet...telnet@ICX7150-C12 Switch#telnet@ICX7150-C12 Switch>enableNo password has been assigned yet...telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 spIncomplete command.telnet@ICX7150-C12 Switch#^Ctelnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 spz10114.bin bootromtelnet@ICX7150-C12 Switch#TFTP: received error request -- code 1 message File no t foundTFTP to Flash Error - code 17telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 mnz10114.bin bootromtelnet@ICX7150-C12 Switch#Load to buffer (8192 bytes per dot)...................SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes pe r dot)...............TFTP to Flash Done.telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08080f.bin primarytelnet@ICX7150-C12 Switch#Load to buffer (8192 bytes per dot)................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ .........................................................................SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes pe r dot)................................................................................... ................................................................................ ................................................................................ ................................................................................ .............................................................................TFTP to Flash Done.telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095gufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardware, abort!File Type Check FailedTFTP to Flash Error - code 8telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095gufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardwar e, abort!File Type Check FailedTFTP to Flash Error - code 8telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095hufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardwar e, abort!File Type Check FailedTFTP to Flash Error - code 8telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095hufi.bin primar telnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardwar e, abort!File Type Check FailedTFTP to Flash Error - code 8telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095hufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardware, abort!File Type Check FailedTFTP to Flash Error - code 8
Thank you for your response and update.
Please ensure that you have the following three upgrade files/patches in your folder shown in the below screenshot:
If you have confirmed the presence of these files, kindly ensure that you select the commands correctly and attempt to execute them again, starting from "copy tftp flash <ipaddress> spz10114.bin bootrom."
Please verify and inform me if this resolves the issue.
Thank you once again for your patience.
I do not see this file "spz10114.bin" in your screenshot.
I see upgrade folder,
I executed the copy tftp flash <ipaddress> mnz10114.bin bootrom
telnet@ICX7150-C12 Switch>enableNo password has been assigned yet...telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 mnz10114.bin bootrom.Invalid input -> bootrom.Type ? for a listtelnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 mnz10114.bin bootromtelnet@ICX7150-C12 Switch#Load to buffer (8192 bytes per dot)...........................SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes per dot)...............TFTP to Flash Done.
Also in the document it says to execute
copy tftp flash 10.176.220.51 SPS08095hufi.bin primary” (upgrade the image)
I do not see this file "SPS08095hufi.bin" in the upgrade folder.
As mentioned in the article, use 8095g in place of 08095h.
As you have executed 'copy tftp flash 192.168.1.155 mnz10114.bin bootrom' command, please go to the next set of commands as described in the guide. Let me know if it works.
I executed next command but failing at "copy tftp flash 192.168.1.155 SPS08095gufi.bin primary"telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08080f.bin primarytelnet@ICX7150-C12 Switch#Load to buffer (8192 bytes per dot)...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes per dot)................................................................................................................................................................................................................................................................................................................................................................................................................TFTP to Flash Done.telnet@ICX7150-C12 Switch#copy tftp flash 192.168.1.155 SPS08095gufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardware, abort!File Type Check FailedTFTP to Flash Error - code 8
I executed next command and failing at copy tftp flash 192.168.1.155 SPS08095gufi.bin primarytelnet@ICX7150-C12 Switch#The code type 64 is not correct for the target hardware, abort!File Type Check FailedTFTP to Flash Error - code 8
I am available now.
