Hello everyone hope ya'll doing great.
So I moved to this Lennar house and I noticed some devices and knew they are for wifi, so started digging up and investigate on how to use them and ended factory restarted all of them.
I have a RUCKUS ICX-7150-C12P which is hard wired to my ethernet router and I did the factory reset also did all the Switch Routing Code (SPR) issue using Command Line Interface (CLI).
Also Have (2) R510 which the PWR light is blinking and the CTL is green fixed other 3 lights are off.
(1) of my R510 is still showing on my wi-fi list as Configure.me-XXXXXX while the other one does no show at all.
Downloaded the Unleashed APP and managed to configurate one of my R510 (the one that says configure.me-XXXXXX but still doesnt change to the name I gave it also its on my network inside of unleashed app that shows over there once in a while. When I check my wi-fi and network It says no internet connection.
I need help please! its driving me crazy.
