When the ruckus switch (ICX 7850) is connected to the cisco switch, can the ERSPAN & RSPAN function work normally?
Hi jjchiou,
Thank you for reaching us out on the query.With regards to the RSPAN settings, with Cross vendor environment we would need to check if the same can work or otherwise.Could you help us with below so that we could check into it further,
Thanks !!
-Joshua
Would the mirrored traffic from the 7850s traverse through connected Cisco Peer ? ( I don’t know if mirrored traffic from the 7850s traverse through connected Cisco Peer or mirrored traffic from the cisco traverse through connected 7850 Peer)
User just want check Ruckus ICX 7850-48F peering with the cisco switch , the ERSPAN function is work well 。
by the way , I ca't reply your mail directly 。
and I can't upload a image as you asked。
Here as the question is specific on interoperability, would need to know exactly how/what its intended use case would be, as with that we could check further specifically with respect to the bit thats in question.You should be able to attach the Topology snap/picture on to the comment, with that it would be easier for to follow the flow of traffic and understand the query better.
The latest progress is that we will send ruckus to the customer and do POC in the customer's actual environment to see the actual results, so this problem can be ended
Understood, that would be able to give us a better understanding of the system.And should there be any issues/concerns seen during the PoC, Feel free to reach us @ Contact Us.
- Joshua
