Hi @Jnava808
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering up and you tried to reset it multiple times.
Please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet. Please refer to the below pictures as an example.
Please use the below link to upload a VIDEO: (Refer to the EXAMPLE VIDEOS from the guide)
Thank you for the reply, images and video have been uploaded.
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
My ruckus is doing the same I don’t think mine is in warranty. Will they still replace it and I don’t see the link that you put in the description
