I’ve attempted the following but failed:
power on and off
scan for IP, no IP associated ruckus
physically connect
Hi @Mel27
Thanks for your response,
Good to hear that the issue got resolved.
Please feel free to mark the case as ACCEPTED SOLUTION. Also please let us know if you have any queries in this regard.
Greetings of the day,
Thanks for the detailed description,
Based on the images you have shared it seems like the switch has steady green lights on it which means that you switch is in good condition.
To find the root cause of the issue please try to take the console access to the switch to check whether the switch is able to transfer the power to PoE devices via 12 ports.
There are two ways to get the access to the switch.
By IP address: To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12CP-Ruckus-Switch/td-p/46759
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
Hi Jayavidhya, Thabk you for the reply
I tried both way but it did not work
1. By IP address, the software did not return any IP address associated with ruckus
2. By console, putty showed an error to connection and Mobaxterm did not have any connection listed in the drop down
can you please advise how to proceed
To solve this issue please share the screenshot of the errors you are getting while following the steps.
