AP is offline and only showing solid red light. How do I resolve?
Hi @Maleen
Greetings of the day,
Thanks for your detailed description,
For further troubleshooting steps please share the image of the switch and the access points showing the LED status and the cable connections as mentioned below.
Also please let us know how many access points are connected to the switch.
I have same issue. Factory reset did not do anything
Hello @sjanik
As this case case was raised by @Maleen which is old and now closed.
I have noticed that you have posted another inquiry on the Lennar forum. Kindly follow the same post thread for further assistance. You can access the thread using the following link:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Had-a-power-surge-last-night-at-my-Lenner-home-and-now-I-have-no/m-p/80874#M18888
Rest assured, I will be available to assist you with your query within the existing thread.
Thank you for your understanding and cooperation.
