Hi -
I know a lot of posts about this and I've looked at a lot of them. I just bought a home that has a Ruckus Lennar Home system in it. I'm somewhat technical and since I do not have the Wifi Password I am trying to reset the system. Currently I see the system is set up and accessing the 2 access points as well. I have the 7150. I also have Internet connected to it and can see the 2.4Ghz and 5 Ghz networks are connected as the WAPs show amber lights. So I figured easy step is like others said to just hard reset so I can see the configure network, connect to it and then be off a running to set up my new network and password. Problem is when I use the paperclip to hard reset it does flash and goes to amber on the 7150 and looks like going to reset. However goes right back to the network already set up and can't get to reset. What am I missing and what should I do next? I tried doing reset several times and had the WAPs connected and then tried without them connected and still same result. I think everything working great, I just don't know the password and can't get the 7150 reset to factory so I can reset it up. Thanks for the help!
