How can we get help for icx 7150 to turn on
Hi @Vasayasultan
As you mentioned there are lights on the PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
We will try to reset the Switch as described below VIDEO:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
As per the case description, I understand that your RUCKUS setup is not working after a power outage.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
1. It was working since 2019
Yes there was a power outage
2.yes there is light on it like power is green and syst is amber
3.yes I have internet service in the house
4.access point are no light at all
Reset worked but after a lot tries.
So I don't have to update or any right?
Currently it's on version 08.0.90dT211
Both partion
Please reply
