I have a Lennar home with an ICX 7150 12P switch connected to two R510 access points. One of the APs is located on the third floor and the other on the second floor. The one on the second floor is connecting but the PWR light is blinking green. I’m able to set up the AP as master by connecting to the Configure-me-xxxx but when I try connecting to the SSID after setup it doesn’t connect.
I’ve tried using the AP on the third floor as a master and had no issue, except I can only see the third floor AP on the web UI, the second floor AP although it’s connected and shows the lights on does not show in the web UI. I tried moving the AP located on the third floor to the second floor connection and have the same issue. The two APs and my router are connected to the switch in one of the 12 ports. My router does have WiFi turned on and is broadcasting a 2.4g and 5g network but I’m not connecting to that. Please help
