Ever since a short power outage 2 weeks ago, been having reduced speed with the Router. Checked my AT&T and seems that router is fine. Any solutions?
Hi @Kyle
As per the case description, I understand that your RUCKUS setup is not working after a power outage with the Internet intermittent connection.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
Please follow the below steps and help us with the queries:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Note: Hit Enter to accept each command.
show version
show flash
I'm currently stuck at the the Mobaxterm step.
I was able to scan for the IP address and login using SSH Session.
Login: admin
Pass: Lennar
But its only giving
Welcome to Ruckus Unleashed Network Command Line Interfaceruckus>
instead of
The ‘ruckus>’ prompt you are seeing is of Unleashed and the RUCKUS ICX-7150-C12P Switch.
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch and try to access the CLI.
Thanks, Imran. Do you mind reattaching the screenshots? Not seeing in the last post
I'm getting this platform when i type in the IP address...
The dashboard you are seeing on the web browser is of Unleashed and NOT of the ICX-7150-C12P Switch.
I've used all three ip address of the Ruckus. And they all lead me to the unleashed platform. Any help?
If you are unable to get the IP address of the Switch, please try getting console access to the Switch and help me with the command outputs I shared previously.
Here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard OR Console cable Rj45 to USB (Any one cable- please refer the guide)
How to console in the ICX-7150-C12P:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Once you are logged in to the ICX-7150-C12P please follow and perform the commands and help with the outputs.
