My Switch will not stay powered on. I have done everything listed in the following post. I know how to use Putty. All lights flash amber for a quick second than turns off. https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Dead-ICX-7150-C12P/m-p/54535#M5705
https://community.ruckuswireless.com/t5/ICX-Switches/ICX-7150-Ruckus-Switch-Lennar/m-p/68872#M4803 this was the ticket I had put in
Hi @Danr831
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering on.
Could you please let me know if you tried to reset the Switch using a paper clip? If not please, try to reset the Switch as described in the below VIDEO.
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
If the reset doesn’t work, could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and working power outlet? Please refer to the below pictures as an example.
