Ruckus ICX 7150-C12P stuck in “Boot Mode” (amber SYST and green PWR) no power to AP.
Attempted numerous resets (remove and return power).
- Returns to amber SYST and green PWR.
Attempted “factory reset”s (Remove power from the switch; Press and hold the Reset button while applying power to the switch; After all the system LEDs flash amber, release the Reset button).
- The system LEDs continue to flash amber for 30 minutes before retry.
- Retry: The system LEDs continue to flash amber for 6+ hours.
Successfully “consoled” into switch and ran “powercycle”
ICX7150-Boot>powercycle
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
device 0 offset 0xbfe00, size 0x200
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
4 ecc_errors after reading 5efa000:5efbc00
iproc_nand_read_page returned 2
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
8 ecc_errors after reading 1b48000:1b49c00
NAND read from offset 0 failed -22
0 bytes read: ERROR
- Unable to get kernel image from either partition.
Attempted software recovery (made, and confirmed, recommended IP changes; pinged TFTP).
printenv
baudrate=9600
ipaddr=192.168.0.2
serverip=192.168.0.2
netmask=255.255.255.0
gatewayip=192.168.0.2
uboot=mnz10115.bin
image_name=sps08095kufi.bin
ver=10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
ICX7150-Boot>ping 192.168.0.2
bcm_xgs_gmac-0 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Auto-neg error, defaulting to 10BT/HD
Change GMAC speed to 10MB
Using bcm_xgs_gmac-0 device
ARP Retry count exceeded; starting again
ping failed; host 192.168.0.2 is not alive
- Failed ping.
- Verified all firewalls were disabled. Ping failed again.
- Swapped out PC/console. Repeated steps. Ping failed again.
I attempted Software Restore/Upgrade from USB. Final steps require “User EXEC mode” for Mount and copy commands.
- “ena” command is not recognized in Boot mode.
I tried 3 PCs/Laptops, two types of connectors, confirming IP addresses, and disabling all firewalls and I cannot get a successful ping.
All suggested solutions seem to require a successful TFTP connection or access to User EXEC mode. Please help.
