I installed the drivers for Mac and tried to connect using the USB-C to USB-C but in the /dev/cu.* there is no device that looks like the Silicon labs. Then I tried a USB-C to USB-A plugged into a dongle that allows me to connect to the USB-C on the Mac. Still no luck. Then I tried the RJ45 plugged into the switch with the other end of the RJ45 plugged into a dongle that goes into the USB-C on the Mac. Still no luck.
What is the best cable combination to connect the switch to a Mac?
Thanks,
Jonathan
