My Ruckus ICX 7150 is not working after power outage. I tried to boot it by connecting my device to laptop but no luck.
Hi @crazy007
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is not working after a power outage.
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
I am not detecting any WIFI signal from the RUCKUS 7150 switch. FYI... I am able to use the internet directly connecting to Spectrum router
As I can see from the screenshot you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
I had tried resetting it for 15 times but no luck.
I had executed software recovery steps till the Putty COM3 screen. I am getting error when trying to connect to COM3
Could you please share a picture showing the software recovery cable connections between the Switch and Laptop. Also, please share a screenshot of the Device Manager showing the COM ports information.
Here are the requested pictures
Could you please double-click on the devices highlighted in the below screenshot and see what it shows? Also please help us with the screenshot of the same.
