Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:972 save key, <697: /usr/sbin/apmgr -r start >, main/bkup ver=215/214 rop-11302/wop-89. xact=0x1f7edb8
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1104 to del backup file: /writable/data/config/master_4_214. xact=0x1f7edb8
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 84760 bytes to /writable/data/config/master_4_216
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 84760(subtotal 84760) of 84760 bytes to /writable/data/config/master_4_216
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /writable/data/config/master_4_216: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1874 to update rpm tmp copy, revision 3, bytes:117548
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 117548 bytes to /var/run/rpmkey3
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 117548(subtotal 117548) of 117548 bytes to /var/run/rpmkey3
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /var/run/rpmkey3: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_set_tmp_copy_revision:1748 set revision 3 to /var/run/rpmkey.rev successfully(1 bytes written)
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1888 updated rpm tmp copy succesfully, new revision 3, to del old revision 2
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_del_tmp_copy:1771 to del /var/run/rpmkey2
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1117 save key finisned successfully, <697: /usr/sbin/apmgr -r start >, main ver=216 rop-11302/wop-89. xact=0x1f7edb8
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:972 save key, <697: /usr/sbin/apmgr -r start >, main/bkup ver=216/215 rop-5/wop-6. xact=0x1f7edd0
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1104 to del backup file: /writable/data/config/master_4_215. xact=0x1f7edd0
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 84672 bytes to /writable/data/config/master_4_217
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 84672(subtotal 84672) of 84672 bytes to /writable/data/config/master_4_217
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /writable/data/config/master_4_217: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1874 to update rpm tmp copy, revision 4, bytes:117460
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 117460 bytes to /var/run/rpmkey4
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 117460(subtotal 117460) of 117460 bytes to /var/run/rpmkey4
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /var/run/rpmkey4: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_set_tmp_copy_revision:1748 set revision 4 to /var/run/rpmkey.rev successfully(1 bytes written)
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1888 updated rpm tmp copy succesfully, new revision 4, to del old revision 3
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_del_tmp_copy:1771 to del /var/run/rpmkey3
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1117 save key finisned successfully, <697: /usr/sbin/apmgr -r start >, main ver=217 rop-5/wop-6. xact=0x1f7edd0
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:972 save key, <697: /usr/sbin/apmgr -r start >, main/bkup ver=217/216 rop-437/wop-125. xact=0x1f7edb8
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1104 to del backup file: /writable/data/config/master_4_216. xact=0x1f7edb8
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 84664 bytes to /writable/data/config/master_4_218
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 84664(subtotal 84664) of 84664 bytes to /writable/data/config/master_4_218
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /writable/data/config/master_4_218: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1874 to update rpm tmp copy, revision 5, bytes:117452
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 117452 bytes to /var/run/rpmkey5
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 117452(subtotal 117452) of 117452 bytes to /var/run/rpmkey5
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /var/run/rpmkey5: check sum ok
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_set_tmp_copy_revision:1748 set revision 5 to /var/run/rpmkey.rev successfully(1 bytes written)
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1888 updated rpm tmp copy succesfully, new revision 5, to del old revision 4
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_del_tmp_copy:1771 to del /var/run/rpmkey4
Jul 28 10:29:47 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1117 save key finisned successfully, <697: /usr/sbin/apmgr -r start >, main ver=218 rop-437/wop-125. xact=0x1f7edb8
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:972 save key, <697: /usr/sbin/apmgr -r start >, main/bkup ver=218/217 rop-13/wop-10. xact=0x1f7ef78
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1104 to del backup file: /writable/data/config/master_4_217. xact=0x1f7ef78
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 84672 bytes to /writable/data/config/master_4_219
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 84672(subtotal 84672) of 84672 bytes to /writable/data/config/master_4_219
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /writable/data/config/master_4_219: check sum ok
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1874 to update rpm tmp copy, revision 6, bytes:117460
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:919 to write 117460 bytes to /var/run/rpmkey6
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_writefile:934 wrote 117460(subtotal 117460) of 117460 bytes to /var/run/rpmkey6
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_validate_write:886 /var/run/rpmkey6: check sum ok
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_set_tmp_copy_revision:1748 set revision 6 to /var/run/rpmkey.rev successfully(1 bytes written)
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_update_tmp_copy:1888 updated rpm tmp copy succesfully, new revision 6, to del old revision 5
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_del_tmp_copy:1771 to del /var/run/rpmkey5
Jul 28 10:29:48 RPM --- @ PID:697 PROCESS:(/usr/sbin/apmgr -r start ) :rpm.c:rpm_savekey:1117 save key finisned successfully, <697: /usr/sbin/apmgr -r start >, main ver=219 rop-13/wop-10. xact=0x1f7ef78
