I have an icX router in my Lennar home. Every time the power goes out we have a connectivity issues. I also did a firmware upgrade but still have issues and you can see that. I also have we’re says the switch is disconnected.failed to ping
Hi @Wecovernc
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
NOTE: Please feel free to mark this post as ACCEPTED SOLUTIONS, if your issues is resolved.
Greetings of the day,
For detailed understanding of the issue please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
https://docs.commscope.com/bundle/unleashed-200.12-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F80103D0.html
RUCKUS LED lights
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
R510’s
unit 1. Lights for PWR,5gand 2.4g are all green
unit 2 lights for PWR,5g,2.4g and CTL are all green
on the main switch. STAT,SYS AND PWR are green and the ports with a CAT 5 cable plugged in are also green.
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working after a power outage.
We will check some configurations on the Switch, please follow the below steps to check the same.
Please follow the below steps and help us with the queries:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
When I log in with putty and get the command line I type enable and it asked for Ruckus# what do I enter?
