How long does it take to receive support from the post?
Hi @Castlcvc
Hope you are doing well!!!
Apologies for the delayed response.
As per the case description, I could understand that your RUCKUS setup is not working, after a power outage.
As we can see from the pictures you shared, there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Also all lights flashing Amber. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
We have already sent you the Software troubleshooting st
Please refer to the same and let us know if you have any queries in this regard.
