Hello, I live in a Lennar home and we started having issues with our equipment within the last two days. All led lights on all 3 of our R510's would turn off every 20-30 minutes, they would boot back up, service restored and then go back down again. I made sure our internet service has been up.
The ICX 7150 switch and I noticed the SYST led would start blinking amber, after a few minutes it would go solid amber, when that happens the AP would lose power.
- The switch (ICX 7150-C12P) SYST light changes from GREEN to blinking AMBER to solid AMBER which then seems to trigger the power cycling of the Access Points.
- Then, the SYST light changes back to GREEN and APs come back online after couple of minutes.
- Then after 15-20 minutes, this cycle repeats.
Tried a factory reset of the 7150 switch and problem continued.
I connected my laptop via USB-C to the switch and Ethernet cable connected between the Out-of-band management port in the Switch and my computer, had Putty open and was getting ready to do a software recovery (Per this help link). Received "is not alive" when tried to ping ping 192.168.0.2
Please help with this ASAP.
