None of the APs (4) are receiving signal from the switch.
I have rebooted the switch and tried to connect via comm port without any luck; amber light stays on.
Hi @Silverbullet
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
Hi Imran:
1. This is not a new install. However, it is a replacement for the original unit which was replaced 10 months ago. I included the SN in a previous message.
2. Unit is set up identically to the last unit and was working fine. Not sure If I had a power failure since everything else is in order but from what I can tell the unit is stuck in boot mode. I am unable to connect to the ruckus via computer to switch. Tried putty and the other app as well.
3. Service from the internet provider is stable. I have Smart Home Monitor which I monitor regularly.
4. There are 4 APs connected.
5. Status lights have not changed. One amber and one green; no other lights are on.
Is there a number I can call someone to discuss?
If in fact this is a power problem, why didn't someone recommend installing a UPS?
Apologies, Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model only.
As you mentioned there are Amber and Green lights, If there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Hi Irman: What type of UPS do you recommend? I’m going to purchase one small enough to fit inside the cabinet.
Could you please let me know if you were able to resolve the issue with your Switch which is stuck on boot mode?
And we recommend getting help or suggestion from a technician regarding UPS.
Please let me know if you have any further queries in this regard.
Imran: I'm getting ready to download the software to kick things off... I'll let you know how it goes.
Hi Imran: I sent you a video last night; I might have to send you another one later today. I also wanted to remind you that the switch I have is a replacement (remanufactured by Ruckus) that replaced the original switch I had. Therefore, I am very familiar with putty and how to get into the ruckus etc. It's just not happening. I actually tried numerous times last night... I have also tried the paper clip and power route countless times without success. Cheers!
Thank you for the response and for sharing the requested information.
Based on the troubleshooting done, you confirmed, and we saw that after the reset, booting up the Switch, and trying the software recovery process multiple times, the failure persists. And the management port is not responding. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again. We appreciate your patience and cooperation.
