had a power outage today and now my access points arent working. I tried to follow a thread from a previous post about the command prompts but switch>enable is not recognized as an internal or external prompt
Hi @Jhiggins91
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS Access Points are not working after a power outage.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same showing the light status and the cable connections to the Switch)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights. Also, light the status of Access Points.
Please let us know the answers to the above queries or if you have any queries in this regard.
I have 2 access points. One upstairs and one downstairs neither one have any lights on. My switch has a green light and an orange light. The orange light is on syst.
Thank you for the information you shared,
As you mentioned and we can see from the picture you shared, there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
IF STILL RESET DOESN’T WORK: Please follow the below steps.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
So I attempted to do the steps provided. However the link https://github.com/peacepenguin/tftpd64/releases is not even a working link. I’m done with this lennar crap and want to know what I can do to actually get someone out here to get it fixed.
