I had to power house down to fix the A/C unit and I can't seem to get my LAN ports to activate. The access points work ok, I have the blinking green lights but nothing connected to the ports seem to get internet. HELP!!
Hi @MrAntCali48
Yes, I can see from the pictures shared, earlier your Switch was booted up on the secondary partition which is on SPR (Routing Code) and now you have your Switch booted up on the Primary partition which is on SPS (Switching Code). It must be on the SPS code for Lennar Home users.
Earlier:
Now:
To avoid this issue in the future please execute the below commands on the CLI to bring your Switch Secondary partition also on the SPS code. In case your Switch boots up on the secondary partition in the future due to power outage/power spikes there won’t be any such issues.
show version
copy flash flash secondary
Example:
ICX7150-24P Router>enable (hit enter to accept the command)ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished) ICX7150-24P Router#boot system flash secondary yes (hit enter to accept the command: the switch will reboot)
Hope you are doing well!!!
From the case description, I could understand that your RUCKUS setup is not working after a power outage/surge.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights. Also, light the status of Access Points.
Please let us know the answers to the above queries or if you have any queries in this regard.
Goodmorning Imran,
Thank you for your response, Here are the pictures show the status of my unit.
Status, Syst, Pwr is GreenMy 2 Gig Internet Connection from my Internet Service Provider (ISP) is stable and working. When I connect my Macbook Pro to my router Wi-Fi and ethernet cable from Router is in perfect condition.
Upstairs APDownstairs APShows Disconnection
I have a 2 Gig fiber Router and this is what my AP provides now
also online it's saying that I am missing the IP address for the RUCKUS ICX and I think it is possible that the Ruckus ICX is running routing codes that are wrong?
Also
What cable do you recommend for me to use to Console the ICX? Thank you in advance!
As per the light status of the Switch and the Access Points, they are in a normal state.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show flash
It shows that the switch does not exist just the APs, So I unplugged it again and it was okay for an hour, Speed was 900+ upload and 300+ download from the APs, and the Lan cable, had the Apple TV going to test. After an hour then the movie paused and the Cc was still going
What happens if I just do a Factory Reset, will the license go away, and if it does how do I get it back the way it was when I purchased my house? Thank you in advance, I am studying Networking now so the Command line is a little confusing for me at this point!
UPDATE: Now it is back up and my upload is 939.54 Download 213.08. So it seems it will go in and out.
What happens if I just do a Factory Reset, will the license go away, and if it does how do I get it back the way it was when I purchased my house? Where would I need to go to get the license back or who can come to the house and fix this. Thank you in advance, I am studying Networking now so the Command line is a little confusing for me at this point!
