I have a Ruckus 7150-C12P switch that:
1. Powers on, with 2 lights green2. I'm unable to login to - none of the passwords in the suggestions on https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-passwords-for-the-Ruckus-Wi-Fi-Access-Points/td-p/46740 work.3. That I'm not able to factory reset - I unpower, push the pin, and power on, but that doesn't seem to factory reset.4. That doesn't supply power to my 2 510 APs most of the time.
How do I proceed at this point?
Hi I've factory reset mine, but don't know what to do after. But for me i kept the pin pushed for around 15 seconds until the lights flashed and it worked. However, what's the next step now. Can you provide a link to the guide you're following or just help me
Hi @techo
Greetings of the day,
From the case description, I could understand that your PoE devices are not working connected to the ICX-7150-C12P Switch.
As you mentioned that on your ICX-7150-C12P Switch, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are Two ways to get access to the switch.
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
