Hi.
I have a question to check.
I just started the Ruckus equipment, so I'm lacking a lot.
In an environment previously configured with Ruckus equipment, three out of five switches were replaced by Cisco due to a switch problem.
Previously, the connection between equipment and equipment was composed of UTP cables, but I am thinking of switching to optical cables this time.
I have a question.
1. Does Ruckus equipment have a dedicated GBIC?
2. I checked this and that and that and found that Lucas equipment has a license to use the L3 feature.
Do I need to buy a license to use GIBC 1G as needed?
3. Is Cisco's dedicated GBIC compatible with Ruckus equipment?
4. It has been confirmed that there is no problem in the current UTP cable connection environment, is there a problem if I change it to an optical cable?
※ Change 3 switches to Cisco in an existing Lucusz100, ICX7150 environment
Thank you.
Have a nice day.
