Went on vacation and came home to find the wifi down. I have two AP's and both had no lights. The switch has been an issue since i bought my house. I went to check the switch next. There was only a green and yellow light on the switch. For an hour or so i struggled to log in via USB. A few days later i logged in and realized the images on both partitions wouldn't load. Another couple days went past, and followed a forum to reload the images/ software. I logged in via USB but could not login with the Ethernet. All ip addresses were correct. I cycled the equipment and when it came back the Ethernet showed it was up. I went into putty and saw the icx7150/boot but then a bunch of computer jargon popped up. Line after line came up and then line by line disappeared. I was unable to type any command in. Then i unplugged the Ethernet and everything was fine. I reset my computer/ bridge and it did it again. Same result is happening everytime the Ethernet is plugged in. It seems like the bridge just died. Ive been really busy and my internet has been down for two weeks going on three. A few months ago the same thing happened. When I logged in via USB it fixed itself as soon as I logged in.
