No power on access points
Hi I'm also having the same issue here. The power doest reach the access points. Tried to follow the forum but my Mac can't recognize the drivers I installed.
Hi farazkarami
Hope you are doing well!!!
Thank you for the information you shared,
As per the case description, I could understand that your RUCKUS Access Points are not powering up.
Could you please let us know?
1. For how long have you been facing this issue? Was there any Power Outage?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture)
3. Please make sure the Ethernet cable is connected to anyone in the 12 ports shown in the picture below:
4. Also please Make sure it is plugged into a well-known outlet/power source.
5. May I know how many Access Points are connected to the Switch?
Please refer to the below guide for connection setup:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Most-common-Setups-for-Lennar-homes-users/td-p/47106
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights.
Thank you again.
Lennar Home Community.
Since last Thursday, after a brief power glitch. Nothing was changed or unplugged on the switch. I have Syst green - power green - no amber lights. I have 3 access points.
As you mentioned that, the SYST and PWR lights are green, meaning the Switch light status is in normal condition.
Could you please let me know the light status on the Access Point? Any of these lights are on (Please refer to the below screenshot)
No lights are on. I was able to get to one and plug in an external 12V power supply and it powered up and its working. They do not get POE.
Hi @farazkarami
Thank you for the detailed information you shared,
As you mentioned, and we can see from the picture you shared there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
Please follow the below steps in order to fix this issue:
First, we will try to reset the Switch as described below:
1. Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
3. We must get console access to the ICX-7150-C12P Switch as mentioned in the steps from the guide below:
How to console in the ICX-7150-C12P:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Below are the Guide and Video Link to perform the Software recovery process:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
And..
As your Switch is on the 8061a version currently, it would be great if you could also perform an upgrade of the Software to rule out these problems in the future.
The recommended stable version is 8095g-
Please follow the above troubleshooting steps for the boot mode issue, so that we could assist you with upgrading later.
Same thing happened again. When I try to go in the switch using terminal on my mac it says
Permission denied
Could you please try to factory reset the Switch using a paper clip multiple times (Like 15-20 times)?
Could you please share a screenshot of the error you are getting on the MAC terminal?
Also please let me know if you have a Windows Laptop/PC. That would be much easier.
Refer to the video below which may help you with software recovery using a MAC terminal.
https://www.youtube.com/watch?v=iviyd91HntU
Please help me with the above queries and let me know if you have any queries in this regard.
