There was a blackout and the APs have lost power after that.
Hi Karupasu
Greetings of the day!!!
As you mentioned and we can see from the picture you shared, there is an amber/yellow light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
Please follow the below steps in order to fix this issue:
First, we will try to reset the Switch as described below:
1. Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET DOESN’T WORK: Please follow the below software recovery steps.
3. We must get console access to the ICX-7150-C12P Switch as mentioned in the steps from the guide below:
How to console in the ICX-7150-C12P:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Below are the Guide and Video Link to perform the Software recovery process:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Lennar Home Community.
I have the same issue
same issue here.
I see a lot posts and I was able to access the switch on the browser, but not sure how to power up the APs
Hi @Karupasu
Hope you are doing well!!!
Thank you for the information you shared,
As per the case description, I could understand that your Access Points are not getting power after a blackout.
Could you please let us know?
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture)
2. Please make sure the Ethernet cable is connected to anyone in the 12 ports shown in the picture below:
3. May I know how many Access Points are connected to the Switch?
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights.
SYST = Yellow MS = Yellow PWR = Green
the Ethernet cables to the APs and Ring are connected to 3 of the 12 ports.
I also rebooted the router a couple of times already.
I got mine resolved
Rebooting a couple times worked.
