Only two lights are On in Ruckus ICX 7150-C12P switch. No power in two access points, POE Lan cables are connected properly.
System(SYST) light is solid amber
Power(PWR) is solid green
Kindly help in resetting or fix this issue.
If it's boot config issue then please reply with Mac OS solution.
