We have out AP not working after power outage. I reset the switch, plugged out/in but still no change. I have checked the unleashed app and the switch is showing pending( pending-ip) state. Please help resolve this asap, thanks in advance.
Hi @venkatk
Thank you for the details provided, according to your description, it seems that your Switch (ICX7150 Switch) may be stuck in boot mode, so in order to fix it, you need to get access via console, using two connections one is for console access using the USB to type C cable (the USB will be connected on your computer and the type C on your ICX7150 Switch) now the second connection will be an Ethernet cable from your computer to the out-of-band port on your ICX 7150 Switch) don't worry the next guide explains the port locations and there are pictures about it, however I will advise performing a hard factory reset first, let me add the steps.
1:Factory reset:
When all the system LEDs blink green, all the configuration data are erased and the switch is returned to its factory configuration. When all the system LEDs are solid green, the erase process is complete and the system reloads. Once reloaded and the SYST LED is steady green, the factory reset is complete.
Ruckus ICX 7150/7650 -ERASE SYSTEM TO FACTORY DEFAULT WITH RESET BUTTON(Tutorial video)
https://www.youtube.com/watch?v=6jHMTdo_hK4&t=1s
2:If the Switch is not responding to the factory reset, you need to perform the software recovery process,
Please read the guide carefully before start the steps.
Ruckus ICX Recovery tutorial video
