After a power outage my R510 will not power on. There are no lights turning on.
Hi @Diaz12
Thank you for the details provided, according to your description, it seems that your Switch (ICX7150 Switch) may be stuck in boot mode, so in order to fix it, you need to get access via console, using two connections one is for console access using the USB to type C cable (the USB will be connected on your computer and the type C on your ICX7150 Switch) now the second connection will be an Ethernet cable from your computer to the out-of-band port on your ICX 7150 Switch) don't worry the next guide explains the port locations and there are pictures about it, however I will advise performing a hard factory reset first, let me add the steps.
1:Factory reset:
Ruckus ICX 7150/7650 -ERASE SYSTEM TO FACTORY DEFAULT WITH RESET BUTTON(Tutorial video)
https://www.youtube.com/watch?v=6jHMTdo_hK4&t=1s
Please read the guide carefully before start the steps.
Ruckus ICX Recovery tutorial video
I tried to reset my switch and no luck... I have ICX-7150 12P. I held down the reset button for up to 30 seconds and no lights flashed amber. They flashed amber when I initially plugged the power back in but they never flashed amber again.
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a(24723488 bytes) from PrimarySW: Version 08.0.61aT211Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE==========================================================================UNIT 1: SL 1: ICX7150-C12-2X1G POE 12-port Management ModuleSerial #:FEK3224P0L9Current License:P-ASIC 0: type B160, rev 11 Chip BCM56160_B0==========================================================================UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module==========================================================================UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module==========================================================================1000 MHz ARM processor ARMv7 88 MHz bus8192 KB boot flash memory2048 MB code flash memory1024 MB DRAMSTACKID 1 system uptime is 7 second(s)The system started at 00:02:03 GMT+00 Sat Jan 01 2000
ICX7150-C12 Switch>ICX7150-C12 Switch>PS 1, Internal Power supply detected.PS 1, Internal Power supply is up.PoE Info: Adding new 54V capacity of 124000 mW, total capacity is 124000, total free capacity is 124000PoE Info: PoE module 1 of Unit 1 on ports 1/1/1 to 1/1/12 detected. Initializing....2000 log entries of PoE Event Trace Log Buffer is allocated on unit 1 for unit 1PoE Event Trace Logging enabled for unit 1PoE Info: PoE module 1 of Unit 1 initialization is done.
ICX7150-C12 Switch>TFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed outTFTP session timed out
