I spoke with ring they said I need to contact the HOA. They think the cable is bad. also Wi-Fi is working but not the Ethernet cable.
It’s the tiny cable that runs around the house might be damaged all the internet cables are fine it’s the one that runs into thru the walls
Hi @unalcemal
We support Ruckus devices for Lennar home clients, so will be the R510 Access Points and the ICX7150 Switch, if the cable is damage to can test by changing the cable.
ICX7150 Switches
R510,R310 and R320 Access Points.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
It's good to know we have some suspected culprits. Let us know anything else about it.
Best Regards
Fernando Vasquez
What should I do?
