Initially posted this last week with no response. The switch will not perform basic networking functions like Ping. I've set the environment per the instructions in several posts. Can an engineer please respond with some next steps and/or recommendations.
Our home lost power after which, our ICX7150 will no longer boot. The power light is green and the system light is steady amber. I've attempted a reset after which all status lights blink amber while power light is steady green. I have also tried to perform a software recovery following these instructions: https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
I'm stuck at the point where I test the connection via ping. The switch is not able to connect and gives an "is not alive" message when I ping the server IP. I get the same messaging when I attempt to ping the local IP on the switch as well. I've tried with multiple machines, network interfaces and cables with exactly the same results. Are there any other tricks I can try?
Thank you!
