Hi @nigelcov
If the Switch is stuck in boot mode, there are a way to fix the issue by performing a software recovery, let me add the guide, Please read the guide carefully before start the troubleshooting.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
