Hello
It seems that you have to perform a software recovery.
Symptoms:
*The Switch will not provide power to any PoE devices (Doorbell, cameras, even the Access Points).
*Will not have connectivity to the devices connected to the Switch.
*The ISP router will work fine.
*Console access will be the only access available.
*System light will be yellow/orange/Amber.Please follow the link below to be able to recover your switch:
I've tried this and no luck.
Hi @AmandaO
Please provide an image where you are trying to connect via console. ICX 7150 - C12 P (USB type C to USB ) PC .
Best Regards
Fernando Vasquez
