The power went out due to a storm at my home. Once the power came on the WAP had no lights on it. The brain for the WAP has power and a green and a yellow light on it. Can someone tell me what the issue maybe and how to fix it? thank you
Hi @amishandami
Basically, due the power outage/ power spike the switch went to a state that we called (boot-mode) that is not able to boot up properly.
That does not mean is broken or need to be replace 'in some cases'
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
If that does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted so in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
3-We need to access (physical) using one of the cables to the ICX-7150C12P mentioned on the below guide:
How to console in the ICX-7150-12cp
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Once we are there, we can try to boot up the unit using the following commands:
Boot_primary or Boot_secondary
If that step does not work Software recovery needs to be applied
Here is the guide:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Best Regards
Fernando Vasquez
Hi thanks for all this information. I tried all the methods you suggested and I had no luck. I asked a local company to come check the ruckus console and they have told me the piece is fried or broken. I have only had it for about 1.5yr and I was hoping to have a case opened to see if this can be replaced via warranty. Please help my house is wired through ruckus and wap access and we have no internet due to this issue
Please provided us a picture/ photo when you are trying to access console with the console cables on switch ICX-7150 - C12P and PC connected.
What error were you getting when trying to access the console, you can send it here:
Authentication is enabled in the device for Console/WEB/SSH.
ICX7150-C12 Switch>PoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.PoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.show versionCopyright (c) Ruckus Networks, Inc. All rights reserved.UNIT 1: compiled on Feb 23 2021 at 00:00:27 labeled as SPS08090k(29360128 bytes) from Primary SPS08090k.bin (Non-UFI)SW: Version 08.0.90kT211Compressed Primary Boot Code size = 786944, Version:10.1.15T225 (mnz10115)Compiled on Thu Jan 31 07:08:55 2019
HW: Stackable ICX7150-C12-POE==========================================================================UNIT 1: SL 1: ICX7150-C12-2X1G POE 12-port Management ModuleSerial #:FEK3208P11LSoftware Package: BASE_SOFT_PACKAGECurrent License: 2X1GP-ASIC 0: type B160, rev 11 Chip BCM56160_B0==========================================================================UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module==========================================================================UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module==========================================================================1000 MHz ARM processor ARMv7 88 MHz bus8192 KB boot flash memory2048 MB code flash memory1024 MB DRAM--More--, next page: Space, next line: Return key, quit: Control-cPoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.PoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.PoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.
that is the error i was given by technical help I had look at the issue for me
Sorry for the delay Fernando as I had to have some help to gather the exact authentic information you requested. I have attached screen shots of the issue with the switch. Please advise
It says I don't have permission to upload the images. please help
Like below :
On behalf of Mr.Patel im writing this, im a IT tech for BestBuy I have tried to trouble shoot this device for him and get the info you are asking of him we do not have the connect cable for the console we tried a usb to usb c no response from the console, but upon hard reseting the device thru the pin hole we are still unable to pull a IP address to access the web GUI upon further investigation I noticed the lights on the front of the switch were flickering randomly and as some point even completely turning off and back on if this is not enough to get a RMA then im sure Mr.Patel and anyone on my team would love to have you team view into the clients PC and help us trouble shoot the issue
Hope you are doing well!
Based on the troubleshooting done, and you confirm that the management interface ( console access ) is not working ( no response ) this unit Should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
Like the following example:
