7150 have no status light and We don’t have any power at the R510 access point switches.
I have tried resetting the switches by unplug power but no luck.
I have connected modem only . Is there required model + router?
Hi @VishalJK
Hope you are doin well !
1-Here is a quick guide how to connect the devices correctly and yes Modem+Router or modem router combo is necessary:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Most-common-Setups-for-Lennar-homes-users/td-p/47106
2-On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
Best Regards
Fernando Vasquez
I have the same problem. The system status LED is steady amber which means it is stuck in boot. I have no POE at all to the APs.
Hi @twmcc
Thanks for the details, as you have the switch stuck in boot mode, you need to perform a software recovery, let me add the guide.
Note: Please read the guide carefully before start the troubleshooting, now inside the guide comes another guide to access via console with MAC and windows, once you gain access the commands are the same.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Yarenis Hernández
Hi Yarenis, The IP addresses for setting up my computer, in the procedure you reference, are not readable. Can you clarify please?
I have attached modem/router combo now. Still switch is not working.
The system SYST LED is steady amber and PWR is green. Pnly 2 lights in Switch.
I have added modem router combo now but not working.
I see 2 light in switch SYST is Amber and PWR green.
Please guide next step.
That's another Issue because the SYST light when it's amber it's because the Switch is stuck in boot mode, please follow up the next troubleshooting steps:
1:Factory reset the Switch:
Password Recovery on a Ruckus ICX(Tutorial video)
https://www.youtube.com/watch?v=XJS28DWbHM4
We have reset as per above steps. We are waiting for couple of minutes. Still all lights are amber, any thoughts how long it will take to resent the device?
