A common Lennar environment is a router and one or more APs connected to the ICX-7150, this can include multiple smart devices connected through cable or Wi-Fi.
Some symptoms when the ICX 7150-c12p is running Routing code:
Smart devices like Amazon's Alexa not working as intended.
Unleashed dashboard sometimes not showing as "Connected" on the Internet tab.
Websites not loading.
Several connectivity issues.
This can happen for a multitude of reasons: Maybe the boot preference was not set when configuring the device, maybe the device was never configured and the routing code was set on the primary flash or maybe the images got corrupted after a power outage or a power spike, random reboot, among other possible causes.
VIDEO LINK AS REFERENCE:
https://www.youtube.com/watch?v=Eem1IBgYaWc
1- To fix this, the switch must be accessed via console/telnet or ssh
Default passwords: username: super password:sp-admin or try to use the same as the same to log in unleashed dashboard or mobile app
2-Once we are log in into the switch, we should see the next prompt
ICX7150-C12 Router>
Where it immediately tells us that the routing code is running.
3- Must go to Privilege mode
ICX7150-C12 Router>enable 'then Hit Enter to accept the command'
ICX7150-C12 Router#
4-Run a ‘show version’ to confirm which code is running your ICX 7150-c12p
-Show version
ICX7150-C12 Router#show version
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Apr 6 2020 at 22:40:21 labeled as SPR08080f
(29829112 bytes) from Secondary SPR08080f.bin
SW: Version 08.0.80fT213
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 12:59:22 2018
as we can see in the initial of the output, SPR08080f is being executed, where the third letter means that the switch is executing the routing code.
Important Note
In Lennar homes, the switch must run SPS (switching) and not SPR (routing) code
5-Once the information is confirmed from the ‘show version’ we should run a show flash
-Show flash
ICX7150-C12 Router#show flash
Stack unit 1:
Compressed Pri Code size = 25976488, Version:08.0.80fT211 (SPS08080f.bin)
Compressed Sec Code size = 29829112, Version:08.0.80fT213 (SPR08080f.bin)
Code Flash Free Space = 1057533952
Here we can see that both SPS is installed in the primary image and SPR is installed in the secondary on the switch.
Here to prevent this problem in the future is to run a ‘copy flash flash secondary’ What this is going to do this command is to copy the primary image in to the secondary image, eliminating the SPR image.
Note: if your switching code is in the secondary code we must execute ‘copy flash flash primary’
- ICX7150-C12 Router#copy flash flash ‘primary or secondary’
primary Copy secondary to primary
secondary Copy primary to secondary
Once the command is executed is going to re-flash the images:
ICX7150-C12 Router#copy flash flash secondary
ICX7150-C12 Router#Load to buffer (8192 bytes per dot) ...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
SYNCING IMAGE TO FLASH. DO NOT SWITCH OVER OR POWER DOWN THE UNIT(65536 bytes per dot)...
.............................................................................................................................................................................................................................................................................................................................................................................................................Copy Done.
ICX7150-C12 Router#
6-Once the Step ‘5’ is completed we should run a ‘show flash’ again to verify that both images are running switching code SPS
-Show flash
Stack unit 1:
Compressed Sec Code size = 25976488, Version:08.0.80fT211 (SPS08080f.bin)
7- when completing all the previous steps we execute a 'reload' and confirm the reload of the switch
Note:also you can force the switch to boot up in a specific image:
Boot system flash primary yes ‘to boot up the switch in primary image‘
Boot system flash secondary yes ‘to boot up the switch in secondary image‘
-Reload
ICX7150-C12 Router#reload
Warning: Console login authentication is enabled, please make sure users are configured
Are you sure? (enter 'y' or 'n'): y
Running Config data has been changed. Do you want to continue
the reload without saving the running config? (enter 'y' or 'n'): y
8-we should get access to the switch again
ICX7150-C12 Switch>
Here we see that the switch is running the correct code ‘switching ‘
go to the privileged mode and confirm with a show version that the switch is finally running SPS code
-Enable ‘go to privilege mode’
-Show version ‘Check actual version ‘
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
UNIT 1: compiled on Apr 6 2020 at 22:29:25 labeled as SPS08080f
(25976488 bytes) from Primary SPS08080f.bin
Note: This may be a fix for some users, sometimes the flashes get corrupted, and you need to proceed with an upgrade to the same version or later.
Many times, the copy flash flash does not work properly, and we must run it more than 1 time or reboot the switch and run it.
