When exam finishes, it shows results. You never get feedback about exact questions of cause.
If you don't see exam results, it's probably your browser problem, check if it is supported, and don't use too secure settings. I never had problems with this exams, using Chrome or Firefox. Brave may break pages because it tries to block a lot of staff, so don't use it for exams, or configure it properly.
Ruckus learning materials are good, and if you have some experience in this field, this exams are not really difficult. Just need to read a bit...
