Hi, I wonder if anyone have a similiar problem.
My ICX-7150-48P Switch fan speed keep chancing for some reason. There's nothing abnormal about the configuration, since I have another Switch that basically have the same configuration (other than IP address and stuff, of course). I try to use fanless-mode but the temperature rise around shutdown level which is kinda worries me.
I've looked at a similar topics in here which able to fix the problem by upgrading the firmware. I tried to upgrade them to the latest one (08095) but the problem still persists. You can see the logs below.
I would be really grateful if anybody can guide me of what to check or what to do. Thanks in advance.
Nov 1 14:56:43:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 14:55:13:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 14:45:33:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 14:44:02:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 14:29:12:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 14:27:42:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 14:13:56:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 14:12:26:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 13:55:15:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 13:53:35:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 13:36:20:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 13:34:50:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 13:21:35:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 13:20:05:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 13:08:19:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 13:06:44:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 12:53:43:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 12:52:08:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 12:42:28:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 12:40:58:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 12:30:58:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 12:29:22:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 12:20:07:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 12:18:27:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 12:06:36:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 12:04:56:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 11:55:31:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 11:53:46:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 11:42:26:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 11:40:56:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 11:30:31:W:System:Stack unit 1 Fan speed changed automatically to 1Nov 1 11:28:56:W:System:Stack unit 1 Fan speed changed automatically to 2Nov 1 11:18:15:W:System:Stack unit 1 Fan speed changed automatically to 1
