I am looking to connect 2 geographically distant (> 5 miles) sites. Both sites have dual WAN fail over, and dynamic IP's from each ISP. I am looking for a hardware (or general solution) recommendation to allow a secure connection between both sites that could withstand a WAN fail over at either or both sites.
This is a small group of computers (<10) with low bandwidth (< 1MB/hour) requirements.
Does Ruckus offers any hardware solution which can help with above setup?
Thanks!
Hi Brandan,
You have posted the query under Access points and I don't see your query matching with AP feature set.
Could you confirm what devices you are using and review if question is posted under correct product category?
@syamantak_omer
Currently, I don't have any hardware, I am looking for a suggestion on what to buy for this case. More than happy to move this to the right category. What should I choose?
Thank you,
Brendan
Hi Brendan,
If I only talk about covering site to site connection over WiFi, then you can use our P2P bridges P300 which can connect your two sites as a L2 connection.
For routing and VPN part, you have to rely on your site router/firewall/gateway to secure the traffic between site-A to site-B.
Please confirm if this is what you are looking for?
I am a bit embarrassed, as I am not looking for a wireless solution, due to the distance. I had someone suggest on reddit that Ruckus could be a great hardware solution. When I posted my question, my selection of access point was really wrong.
But my question is about the second option.
