ver 08.0.80caT211!stack unit 1 module 1 icx7150-c12-poe-port-management-module module 2 icx7150-2-copper-port-2g-module module 3 icx7150-2-sfp-plus-port-20g-module!!no global-stp!!!vlan 1 name DEFAULT-VLAN by port no untagged ethe 1/1/2 to 1/1/12 no spanning-tree!vlan 123 name Data by port tagged ethe 1/2/2 ethe 1/3/1 to 1/3/2 untagged ethe 1/1/1 ethe 1/2/1 no spanning-tree!vlan 401 name voice by port tagged ethe 1/1/1 to 1/1/2 ethe 1/1/4 to 1/1/12 ethe 1/2/1 to 1/2/2 ethe 1/3/1 to 1/3/2 no spanning-tree!!vlan 666 name Restricted-Data by port no spanning-tree!!!!!!!!!!authentication auth-default-vlan 123 restricted-vlan 666 dot1x enable dot1x enable ethe 1/1/2 to 1/1/12 dot1x port-control auto ethe 1/1/2 to 1/1/12!!aaa authentication web-server default localaaa authentication enable default localaaa authentication dot1x default radiusaaa authentication login default localaaa authentication login privilege-modeconsole timeout 30enable aaa consolehostname TESTSW02ip address 10.1.13.15 255.255.255.0ip dns domain-list test.testdomain.state.usip dns server-address 10.1.5.40 10.1.5.41no ip dhcp-client auto-update enableno ip dhcp-client enableip default-gateway 10.1.13.1!logging host 10.1.2.3logging consolelogging persistencemirror-port ethernet 1/1/1!no telnet serverusername testwan password .....radius-server host 10.1.120.221 auth-port 1812 acct-port 1813 default key 2 $b24zbw== dot1xcdp runfdp runsnmp-server contact Network Operations Centersnmp-server host 10.1.2.3 version v3 priv testwansnmp-server group testv3 v3 priv access 99 read all write allsnmp-server user testwan testv3 v3 access 99 encrypted auth sha 6974065afb9f99927806e01c6ae2175104870138 priv encrypted aes 6974065bfb9f99927806e01c6ae21751!!clock summer-timeclock timezone us Eastern!!ntp server 10.220.1.1!!web access-group 99no web-management httpweb-management httpsbanner motd ^C------------------------------------------------------------------------^C^CTemporary Infrastructure Test Switch^C^CThis system is solely for the use of authorized test personnel.^CThe information contained herein is the property of test and subject to^Cnon-disclosure, security, and confidentiality requirements.^Ctest will monitor system usage for unauthorized activities.^CAny user accessing this system expressly consents to such monitoring.^C^CAsset xxxxxxxx^C^C------------------------------------------------------------------------^C^C!ssh access-group 99!!!interface ethernet 1/1/1 trust dscp!interface ethernet 1/1/2 trust dscp!interface ethernet 1/1/3 trust dscp!interface ethernet 1/1/4 trust dscp!interface ethernet 1/1/5 trust dscp!interface ethernet 1/1/6 trust dscp!interface ethernet 1/1/7 trust dscp!interface ethernet 1/1/8 trust dscp!interface ethernet 1/1/9 trust dscp!interface ethernet 1/1/10 trust dscp!interface ethernet 1/1/11 trust dscp!interface ethernet 1/1/12 trust dscp!interface ethernet 1/2/1 mon ethernet 1/1/1 both trust dscp!interface ethernet 1/2/2 trust dscp!interface ethernet 1/3/1 speed-duplex 1000-full trust dscp!interface ethernet 1/3/2 speed-duplex 1000-full trust dscp!!!ip access-list standard 99 sequence 10 permit host 10.1.4.5 sequence 20 permit host 10.6.7.8 sequence 30 permit host 10.9.10.11!sflow destination 10.1.2.3 2055!lldp run!!ip ssh authentication-retries 2ip ssh timeout 30ip ssh idle-time 30ip ssh scp disableip ssh encryption disable-aes-cbc!!!end
