Hi - I'm having an issue with trying to get a few R500 APs to preconfigure (in my office) for connection to a ZF3050 controller at another location. Typically I'm able to run putty, connect/log into the device, and run the command "set director IP 192.168.25.50, it says it needs to reboot, and it's done. I take it to the location, connect it to the network, it recognizes the controller, I assign an IP and I'm done. Now, when I attempt to pre-configure, it displays a message "command is not recognized: set director ip 192.168.25.50". I've reset the device to factory defaults, and still get the message. I've even tried the command "set discovery-agent enable", with the same exact result "command is not recognized: set discovery-agent enable". Does anyone know what could be going on here? I'm not sure why its not recognizing these commands. It's not for just one, it's happening on several I have here. Any help or suggestions would be appreciated!
