I have 2 stakcs. One of them has 9 switches and another one has 11 switches. I activate loop detection for all vlans.
When I connect my uplink to stack masters, there is no problem. Loop detection works.
But when I connect uplink to another stack members and I make a loop, loop detection does not work.
Is this a firmware problem or a configuration problem? Have you ever heard of this problem before?
There is stack config below: 5/2/5 is uplink port.
CUS_211_HUKUK# show running-config
Current configuration:
ver 08.0.90jT213
stack unit 1
module 1 icx7250-48p-poe-port-management-module
module 2 icx7250-sfp-plus-8port-80g-module
priority 128
stack-trunk 1/2/1 to 1/2/2
stack-trunk 1/2/3 to 1/2/4
stack unit 2
stack-trunk 2/2/1 to 2/2/2
stack-trunk 2/2/3 to 2/2/4
stack unit 3
stack-trunk 3/2/1 to 3/2/2
stack-trunk 3/2/3 to 3/2/4
stack unit 4
stack-trunk 4/2/1 to 4/2/2
stack-trunk 4/2/3 to 4/2/4
stack unit 5
module 1 icx7250-48-port-management-module
stack-trunk 5/2/1 to 5/2/2
stack-trunk 5/2/3 to 5/2/4
stack unit 6
stack-trunk 6/2/1 to 6/2/2
stack-trunk 6/2/3 to 6/2/4
stack unit 7
stack-trunk 7/2/1 to 7/2/2
stack-trunk 7/2/3 to 7/2/4
stack unit 8
stack-trunk 8/2/1 to 8/2/2
stack-trunk 8/2/3 to 8/2/4
stack unit 9
stack-trunk 9/2/1 to 9/2/2
stack-trunk 9/2/3 to 9/2/4
stack enable
stack mac d4c1.9e77.a9ac
loop-detection
vlan 1810 name Idari by port
tagged ethe 5/2/5
untagged ethe 1/1/1 to 1/1/48 ethe 1/2/5 to 1/2/8 ethe 2/1/1 to 2/1/48 ethe 2/2/5 to 2/2/8 ethe 3/1/1 to 3/1/48 ethe 3/2/5 to 3/2/8 ethe 4/1/1 to 4/1/48 ethe 4/2/5 to 4/2/8 ethe 5/1/1 to 5/1/48 ethe 5/2/6 to 5/2/8 ethe 6/1/1 to 6/1/48 ethe 6/2/5 to 6/2/8 ethe 7/1/1 to 7/1/48 ethe 7/2/5 to 7/2/8 ethe 8/1/1 to 8/1/48 ethe 8/2/5 to 8/2/8 ethe 9/1/1 to 9/1/48 ethe 9/2/5 to 9/2/8
loop-detection
vlan 1911 name Yonetim by port
tagged ethe 5/2/5
router-interface ve 1911
loop-detection
loop-detection-interval 30
errdisable recovery cause loop-detect
errdisable recovery interval 600
enable aaa console
enable acl-per-port-per-vlan
hostname CUS_211_HUKUK
ip dhcp snooping vlan 1810
ip route 0.0.0.0/0 192.168.11.1
no telnet server
username super password .....
hitless-failover enable
sz registrar
interface ethernet 5/2/5
dhcp snooping trust
interface ve 1911
ip address 192.168.11.212 255.255.255.0
end
