I have following problem when enter this:
CUS(config)#arp 95.183.181.254 00e0.4c68.0b7d ethernet 5/1/13
ADD static arp 95.183.181.254 -> 00e0.4c68.0b7d -> 1/2/5 (VRF: 0)
Error - ip address not directly connected
I want to bind my pc ip address with that mac address on 13th port. What am I doing wrong?
Also I have folloing problem too when I try to enter ip source binding:
CUS(config)#ip source binding 95.183.181.252 ethernet 1/2/5 vlan 1810
Warning - IP Source Guard is Not configured on the per-port-per-VE vlan 1810 for port 1/2/5, 95.183.181.252 binding will not be active.
How can I solve this?
This is my running config:
CUS(config)#show running-config
Current configuration:
ver 08.0.90jT213
stack unit 1
module 1 icx7250-48p-poe-port-management-module
module 2 icx7250-sfp-plus-8port-80g-module
priority 128
stack-trunk 1/2/1 to 1/2/2
stack-trunk 1/2/3 to 1/2/4
stack unit 2
module 1 icx7250-48-port-management-module
stack-trunk 2/2/1 to 2/2/2
stack-trunk 2/2/3 to 2/2/4
stack unit 3
stack-trunk 3/2/1 to 3/2/2
stack-trunk 3/2/3 to 3/2/4
stack unit 4
stack-trunk 4/2/1 to 4/2/2
stack-trunk 4/2/3 to 4/2/4
stack unit 5
stack-trunk 5/2/1 to 5/2/2
stack-trunk 5/2/3 to 5/2/4
stack enable
stack mac d4c1.9e77.be10
tftp disable
vlan 1810 name idari by port
tagged ethe 1/2/5
untagged ethe 1/1/1 to 1/1/48 ethe 1/2/6 to 1/2/8 ethe 2/1/1 to 2/1/48 ethe 2/2/5 to 2/2/8 ethe 3/1/1 to 3/1/48 ethe 3/2/5 to 3/2/8 ethe 4/1/1 to 4/1/48 ethe 4/2/5 to 4/2/8 ethe 5/1/1 to 5/1/48 ethe 5/2/5 to 5/2/8
router-interface ve 1810
loop-detection
vlan 1911 name Yonetim by port
tagged ethe 1/2/5
router-interface ve 1911
loop-detection-interval 30
errdisable recovery cause loop-detect
errdisable recovery interval 600
enable aaa console
enable acl-per-port-per-vlan
hostname CUS_211_HAZIRLIK
ip arp inspection vlan 1911
ip dhcp snooping vlan 1810
ip dhcp snooping vlan 1911
ip route 0.0.0.0/0 192.168.11.1
no telnet server
username super password .....
snmp-server community ..... rw
snmp-server enable traps syslog
snmp-server host 95.183.180.42 version v2c .....
snmp-server host 95.183.180.170 version v2c .....
clock timezone gmt GMT+03
ntp
server 95.183.180.6
hitless-failover enable
sz registrar
interface ethernet 1/2/5
arp inspection trust
dhcp snooping trust
interface ve 1810
interface ve 1911
ip address 192.168.11.211 255.255.255.0
arp 95.183.181.254 00e0.4c68.0b7d inspection
arp 95.183.181.1 c091.34f9.0500 inspection
ip source bind 95.183.181.252 ethernet 1/2/5 vlan 1810
ip source bind 172.18.18.18 ethernet 4/1/15 vlan 1810
end
